Reply To: beogram 5500 turntable repair, gear disassembly?
#10739
Beitie
  • Topics Started 2
  • Total Posts 8
That solenoid can be tricky at times. Though if you don’t have any power or motor movement at all, you have bigger issues to figure out.
The solenoid you have pictured reacts based on some micro switches under that PCB. The placement of that PCB and the switches are very delicate and it’s not always easy to get right.
