3 November 2022 at 18:57
#25776
Where did you get that lovely Beo Hub board from? I did have to replace a reed switch and a blown transistor on mine (TR6 I think?).
I have also had to replace the reed switch on a couple of these units, usually after i have invertedly grounded the 6vdc circuit…..its happened a couple of times when the carriage slide has moved too far in when i have been testing with the slider switches removed (schoolboy error)…..
