November 2, 2022 at 12:54 pm
#10600
Don’t change the value of the resistor.
Besides, a 5W resistor will dissipate just as much energy as a 3W if they are of the same ohmic value.
And don’t think a resistor is bad just because it runs warm.
The resistor in question will run warm. If the lamp has been out – or the
Beomaster hasn’t seen use for a long time, dust on the resistor may emit a warm smell
and even a little smoke for a minute or two as it warms up for the first time.
Not unlike many valve-based items.
That’s all normal.
If the resistor has indeed gone bad or measures very wrong, I suggest you ask at Beoparts-shop for a possible replacement.
Beoparts-shop is a webshop, it requires no membership or login.
http://www.beoparts-shop.com
- This reply was modified 1 year, 4 months ago by Dillen.
