Reply To: Beosound overture 2637 with beo4 remote – spares and repairs
#10579
Guy
  • Warwickshire, UK
  • Topics Started 10
  • Total Posts 382
Are there alternatives to the bunny ears?
If your FM signal is strong enough you could always just connect a ribbon aerial like this: https://www.amazon.co.uk/Indoor-Ribbon-Coaxial-Connector-Adapter/dp/B00XA0ZN22
… and hide it behind a curtain or under the table.  Or connect an external aerial if you have one.
My BeoCentre 2300 worked very well with a wire coathanger hooked into the antenna socket!
But the ‘bunny ears’ aerial does look good – if you can be patient you may find one for a reasonable price.
