Reply To: Wanted! Guide for setting up and controlling Light with the Beoremote One/BT.
#10416
Carolpa
  • Topics Started 3
  • Total Posts 84
Edit! Do I understand it correct…..if I use the Beolink Gateway, I could avoid using the second NL/ML Converter, that I am just about to install. Or do I need the (second) converter as well? I have ML products/Master and CD, that I want to be able to use along with my NL devices. MM
You will need both, the BLC (Beolink NL/ML converter) and the Beolink Gateway (despite the hardware is the same).
