October 30, 2022 at 9:51 am
#10411
I have never heard the BL12-2 but have plenty of BL3s.
I would state the BL3s are 2003-5 tech, the 12s a little later. However, it is likely they are just different form factors of the same/similar thing. Although good, I think todays modern Labs will probably blow them away. The BL11 will however lift both speakers in terms of tonal response.
I think the question to ask is what are your labs used for (primary music, surround etc..) and how do they fit with your living and decor?
- This reply was modified 1 year, 5 months ago by Mr10Percent.
