Reply To: Issues Stereo Pairing Beolab 28s
#10389
Olasitu
  • Topics Started 2
  • Total Posts 6
Update …. I tried all possible fixes for the Wireless/Wifi paring without success.
I have switched to the Ethernet connection. One speaker connected to the LAN and the other daisy chained via another Cat 6 directly. So direct Cat 6 connection between the 2 speakers.
System working perfectly! LAN connection appears to be a preferred mode in any case based on the manuals.
Next test is the PowerLink connection between the Speakers and the TV (LG C2) via a Hall Audio streamer. Using DIN/RJ45 connections between the 2 speakers connected directly to the Hall Audio via a PowerLink Splitter. I will post outcomes under another post not to divert the topic of this post.
