Reply To: New product launch – beosound theatre?
#10386
Severed_hand_of_skywalker
  • Toronto, Canada
  • Topics Started 2
  • Total Posts 59
Have you tried switching to WISA on the 18’s? might rule out a wired connection issue as a test, or even just switch to WISA permanently if it fixes the problem?
I did test it yes and the issue went away.  But I also switched cables and speaker positions etc and it seems the theatre is sending out some sound to the right front when you change inputs and volume. Its rather annoying but I’m going to pursue it with support.
