Reply To: New product launch – beosound theatre?
#10356
Mr10Percent
  • Topics Started 2
  • Total Posts 160
Small hint to all installers: If you have a network problem check the network cable, which is delivered with your BS Theatre. Mine was faulty … My dealer had to send it in to the headquarters.
IIRC, installing my Eclipse in 2018, I had exactly the same problem with the hidden connector between the soundbar and the panel. This resulted in having to disassemble everything to re-fit.  I wonder where B&O source this rubbish from?
