October 27, 2022 at 7:17 am
#10255
It appears you are not getting DC voltage from the regulator on PC Bd #2. I would disconnect connector P3 and measure the DC voltage on the input and output of the regulator, IC1. Either C3 or C4 could be a problem but id the fuse is not blowing, I would expect the regulator has opened. It’s not likely the solenoid unless you hear it activate when simply plugging in the power cord. Then either TR4 or 5 could be shorted.
