Home › Forums › General Discussion & Questions › Eclipse/Harmony/Theatre audio via Beolink › Reply To: Eclipse/Harmony/Theatre audio via Beolink
26 October 2022 at 18:39
#26060
You’re looking at it from a family situation perspective. For those with smaller households, or single person households like myself, its a much more obvious usage scenario.
And remember, it worked perfectly well (sync wise) before, so its not obvious what the issue now is. If there is a technical reason its likely in the Eclipse/Harmony/ Theatre – a BS2 cannot be in sync with those, but can be with a BV11, for example.
Anyway, its not a deal breaker for me, I can work around small sync issues. But that won’t be the case for all.
