Reply To: Beosound Core
#10220
N0nl1near
  • Topics Started 2
  • Total Posts 3
Hi Johan,
Thank you very much for your feedback. I considered it but wanted still to try whether I can get a better sound quality instead of using the AirPlay2 using directly the phone connected to a DAC and then through a cable to the Core.
Do you see a chance to do it without having to connect/disconnect the cable behind the Core?
Thanks a lot for the kind feedback!
