October 26, 2022 at 3:38 pm
#10215
Any ideas before it goes back in the box for another day? Is anyone actually using a Beoport successfully based upon a (much) earlier Beoplayer install?
I have and use Beoport/Beoplayer on my 64 bit Windows 7 which works fine.
The only issues relate to the N-Radio where many of the stations are available to select, but never connect. In the UK selection all the BBC stations work and a few lesser known also work, but most just sit trying to connect which almost certainly means the linkage to the station was removed.
In fact back in 2005 I actually helped B&O debug their software and it took a long time before it became a useable product.
