Reply To: New product launch – beosound theatre?
#10171
SimonWeir
  • Topics Started 1
  • Total Posts 23
You can set the guide button in the Sky Q settings to take you to the home menu.  This follows through when using PUC.  Using the Beoremote with Sky Q in your hand is more natural than the OEM Sky remote as the home button is a stretch for your hand being in the centre of a wide remote.
Have no fear in making the change the beoremote is another thing B&O do so well… it just works with every source.  I have it set to Sky Q on PUC A and Apple TV4k on PUC B.  Just a shame only 2 PUCs as HDMI-CEC for my Blu-ray is not as good as PUC, which I had before on the Eclipse, so I will when loading the actual disc use the on the player controls to get the movie playing.
