Reply To: Beogram 1900 “Restore”
#10170
adyan
  • Topics Started 1
  • Total Posts 12
Thanks for you answer, Martin.
Not sure what you mean with “correctly aligned axialy”, put everything back together as it was before… There is nothing to adjust, is there?.
If the motor is turned manually (or if the power is disconnected) it runs fine and silent, as soon as the motor gets power there is relativly loud noise and the whole motor gets very hot, so hot that it is not touchable…
My thinking it´s an electrical problem, not a mechanical.
From your experience: Do these motors go bad?
To answer your take on 50/60Hz, yes it´s a 50Hz deck used in germany.
Thanks in advance
Christian
