Reply To: New product launch – beosound theatre?
#10162
Sandyb
  • Topics Started 1
  • Total Posts 108
Thanks for the write up, very informative.
Can I ask a quick question re controlling Sky Q. I am presuming you are using a PUC cable between the Theatre and the Q box to allow Beoremote 1 control.
When you have Sky Q selected as an input, and are watching, does the Guide button on the remote control actually bring up the Sky guide/planner? Or, as my dealer tells me, does pressing Guide actually pull up the internal tuner TV guide? and therefore, to access the Sky planner requires a few button presses (I think Home/Menu on the BR1 and then finding the guide function from a list of commands)
I ask as am thinking of moving to a Theatre setup, from an older BV12-65 setup – and in my current setup, if I am watching Sky pressing Guide on the BR1 works as it should, and brings up the Sky guide/planner.
What my dealer describes would seem like a backwards step integration wise, but am looking for someone to confirm.
Sorry for the question, but as someone with a Theatre and Sky, I was hoping to get some clarity.
Otherwise, congratulations on the set up.
