Reply To: New product launch – beosound theatre?
#10159
Mark
  • Topics Started 1
  • Total Posts 44
so I have needed to put my UHD into the LG G2 to use the universal control HDMI-CEC, but as the pass through is now the reverse path, for some unknown reason it doesn’t recognise Atmos via bitstream and so still needing to use PCM to get 7.1. From the Panasonic DP-UB820EB.
Thank you for describing the issues you are having.  I hope somehow I can benefit from this knowledge, or at least know what to expect.
I am having a little difficulty understanding the issue with the UHD player.  When you say “reverse path”, do you mean the audio goes to the TV and then to the Theatre via eARC or something else?  Atomos isn’t recognised this way?  It is supposed to right?
