Reply To: beogram 5500 turntable repair, gear disassembly?
#10109
ummagumma
  • Topics Started 3
  • Total Posts 35
Pulled it apart & checked the solenoid, both coils appear to have continuity, so I don’t think it burned up.
Also removed & tested diodes 3,4 as they are in the solenoid circuit. Both tested good.
Very impressed with how serviceable B&O makes their stuff. Clear labelling on the PCB’s, and hinged cases for access. I discovered the lid support wire at the back, which is convenient. I had been propping the lid up with a hook screwed into the wall earlier.
Connector P6 is the most awkward thing I have ever seen though. By the time I wriggled it off, I had to resolder all the connector points under the board since some of the pins came loose.
5500 turntable still won’t power up.
Am I posting this in the wrong section? Surprised no one has replied? Has nobody here repaired one of these before?
Thx
  • This reply was modified 1 month, 2 weeks ago by ummagumma.
