Reply To: New product launch – beosound theatre?
#10102
beojeff
  • Topics Started 2
  • Total Posts 63
For me, I’m using an LG C2 77″ screen wall-mounted with the Theatre also wall-mounted separately. I didn’t really like the G2 because of its box frame — which is truly meant to be flush with the wall. I’m using a wall-mount that will allow me to pull the screen away from the wall to have access to the sockets when I need that access.
In the past, I’ve had a dual screen/projector setup for when I want to use the CINEMA mode. However, I’ve found that with the large and bright TVs now available (I’ve currently been using a Samsung 75″ 4k) that I no longer ever use the CINEMA mode with a projector. I might move the projector to use with the jacuzzi bathtub with the now available Beosystem 4.
