Reply To: Beogram 1900 “Restore”
#10091
adyan
  • Topics Started 1
  • Total Posts 12
Hello again,
got some parts from beoparts, still having trouble…
Changed bearings and belt but doesn’t work properly. Still to slow and motor is getting way to hot. Also motor is noisy, thought this was a bearing problem but isn’t. Noise is only there when motor ist powered, otherwise seems to run smooth and silent.
Found this:
https://archivedforum2.beoworld.org/forums/p/6873/62531.aspx#62531
but as far as I can check this is not my problem…
and this:
https://archivedforum.beoworld.org/forums/t/38447.aspx
Both of my coils measure the same, about 167 Ohm.
Because the motor gets so hot I think there is probably shorts in the coils?
Any tips what to check? Do I have to find another motor?
Thanks in advance
Christian
