Reply To: BeoLab 8000: 5-pin cable from RCA-PCB to LED-PCB sensitive
#10086
Die_Bogener
  • Topics Started 1
  • Total Posts 94
Solder it.
Hum is just some millivolt.
Copper, mixed with chromeplated steel and nickel will always make some chemical noise.
You can also make a special shortcut plug for testing. Just a shorted Cinch connector.
Then you can test wether there is still humming…
