23 October 2022 at 10:20
#26158
Thank you for the description, I had not noticed the ability to pull the knobs off like you mention. Then I might have another issue, and that is that the buttons do not thay IN when being pressed. There was a small blade spring that has become loose, it was attached to the P2 button on the side but despite trying mounting it differently I cannot make it work – I assume it have something to do with the plastic thing moving underneath the buttons?
Can you help with that also?
/Pindsen
