23 October 2022 at 04:56
#26163
Is there anything other than a dead solonoid that will show symptoms like this?
The unit doesn’t even power on anymore. As I said, the fuse is ok.
I might check transistors 4, 5 as they are in the same circuit as the 2 relays/solonoid.
