Beo6 2-way no longer working
This post has 12 Replies | 2 Followers
Griebel
Posts 344
Griebel Posted: Thu, Mar 20 2014 8:29 PM
I have been using the 2-way function of the Beo6 remote connected to a BeoMaster 5 for some time. Had a general power failure. Everything went back to normal functioning (TVs, BM5, network etc), but all my remotes can no longer access the media list of the BM5 despite the remotes connecting normally to the BM5.
When I select N.MUSIC, it starts BS5 and/or the connected TVs/speakers, the remote is trying to access the BM5 files, but after a few minutes searching got an "unable to connect" message.
This happens with all of Beo6 remotes, which tends to indicate that I missed something with the BM5 setup or???
Does anyone have an idea of what went wrong?
pf85
Posts 284
pf85 replied on Thu, Mar 20 2014 8:39 PM
Have you checked if IP address on Beo 6 corresponds to IP of BM5 ?
AudiA4
Posts 4
AudiA4 replied on Thu, Mar 20 2014 8:42 PM
Maybe BM5 IP changed after power failure? This IP has to be configured in Beo6.
Griebel
Posts 344
Yes, the IP of the server of the Beo6 corresponds to that of  the BM5, and like I said the connection establishes, after I exit the service menu of the remote, the WiFi sign shows on the top right corner. Everything seems fine, but when I select N.MUSIC the remote is unable to access the media files of the BM5.
Have being doing this many times in the past, but here I have no clue why it doesn't work anymore.
tournedos
Finland
Posts 7,302
tournedos replied on Fri, Mar 21 2014 8:01 AM
Unless you have configured a custom netmask at the router, your Beo6 and the BM5 seem to be on different subnets (192.168.100.x versus 192.168.1.x) so broadcast IP traffic won't typically work between them. Is the BM5 connected to wired network instead of WiFi?
I have no experience with either system, so I don't know if it is possible to make it work with different subnets, but in any case I'd expect it to need some configuration at the router so that the systems can communicate with each other.
--mika
Johan
Uppsala, Sweden
Posts 239
Johan replied on Fri, Mar 21 2014 10:20 AM
tournedos:
versus 192.168.1.x
And by 1 you mean 0, right? Smile
But yes, your reasoning sounds about right.
/  Johan
Griebel
Posts 344
Griebel replied on Fri, Mar 21 2014 5:31 PM
Indeed I noticed that the Beo6 IP is automatically on a different subnet than the server, which I have some difficulty to understand why. Moreover you can't change the Beo6 IP manually. I guess that's the reason why it doesn't work. But how to solve the issue, how to give the same IP subnet to both the Remote and the server when it is configurated automatically?!
tournedos
Finland
Posts 7,302
tournedos replied on Fri, Mar 21 2014 5:59 PM
I believe the answer is in your router configuration, which we don't know anything about. The Beo6 gets its IP via DHCP from a device that is serving the IP numbers somewhere, and so does the BM5 (unless you have configured it to a fixed IP number).
You either have now two DHCP servers in your network, or the router serves two different subnets - possibly one for WiFi clients and another for wired clients. That's sometimes a desired setup to isolate the wireless clients from the rest of the network (only allowing access to outside world through the router).
Unless you have already done so, I would start by 1) rebooting your router 2) then the BM5 3) then the remotes to rule out any transient problems with how they came back up after the power break. If it still doesn't work, I guess it's time to start going through the router config.
--mika
Griebel
Posts 344
Griebel replied on Fri, Mar 21 2014 7:01 PM
Thanks Mika for these detailed explanations. Will proceed as suggested and let you know.
Griebel
Posts 344
Griebel replied on Wed, Mar 26 2014 6:10 PM
Finally I could successful setup one of the Beo6, which is now connected to the BM5 and has access to the music library.
Unfortunately, though following the exact same procedure, I didn't succeed in connecting my 3 other Beo6 remotes. They keep connecting to the wrong network?! To bad it's not possible to enter manually the IP address of the Beo6 (although it's possible for the server).
Griebel
Posts 344
Griebel replied on Sat, Mar 29 2014 10:39 AM
Problem solved. There was an access point in the network which caused the trouble. Rebooted the access point and now all the Beo6 get the correct IP.
Edoardo
San Marino
Posts 137
Edoardo replied on Sun, Apr 13 2014 5:01 PM
Hello, I am happy to know you got to fix the problem.
I just wanted to adk you that:
As myself too own a beosound 5 / Beomaster5 and a remote Beo6, I would like to use the remote to command the Beosound 5 (with net music and net radio); you know that with the Beo4 is not good (you can not choose the song or the album, but just advance one by one.
So I tried to set the Beo6, following the instructions found in the B&O Website, but it doesn't work.
Did you set up the remote by yourself or the B&O assistance did it?
All the best
Griebel
Posts 344
Griebel replied on Mon, Apr 14 2014 7:50 AM
To program the Beo6 remote better ask your dealer. You need a special software (ConfigTool) to do it. It´s not intended to be used by users, although a lot of them use it, but they generally have minimal programming knowledge.
Note that programming of Beo6 by B&O is (generally) not free.
Page 1 of 1 (13 items) | RSS
