Beocenter 9500 screws
Answered (Verified) This post has 3 verified answers | 12 Replies | 1 Follower
Fixer
Fixer posted on Wed, Apr 25 2012 6:35 PM
So I have got a replacement part on order and the whole thing back together and fully (well almost) working again!
I have 2 problems at the moment.
The screws which are removed along the back (heat dissipation grille) to put the 9500 in the service position were practically ground down when I came to remove them (looks like someone had a go previously). All of this set are of no use. I tried screwfix and Maplins but both can't match the size. Does anyone have any ideas of where I can get some of the same size?
Second problem is the passive speaker out terminals don't work or only cut-in in a very broken manner. Connecting to the MCL they work fine but mute then doesn't work on them (Beovox cx50's). Other than trying to clean inside the terminal connections, has anyone experienced this problem before?
Thanks for any help
jlehtinen
Sweden, Stockholm
Verified by Fixer
Sounds like you are having problem with mute relay. I just few days back replaced same relay in my BC9500. You can try to "clean" the mute relay or just replace it. Some say that cleaning is not a long term solution though. You can try to push mute button several times and see if sound quality gets any better.
Jyrki
joeyboygolf
Ely, Cambridgeshire, UK
Verified by Fixer
The screws are M3 * 10mm Torx black set screws
Regards Graham
tournedos
Finland
Verified by Fixer
Fixer:
Would that still allow the MCL speaker connection to work?
Yes; the local muting function of the Beocenter won't affect the second speaker outputs. Otherwise you couldn't mute the local & link rooms independently from each other. The MCL boxes have their own muting relay.
As Graham said the screws have originally a Torx T10 head. Some knothead has probably destroyed them with a Phillips driver because he was too cheap to invest 3€ in a proper tool. You can replace them with regular Phillips screws if you want.
--mika
jlehtinen
Sweden, Stockholm
Verified by Fixer
Jyrki
jlehtinen
Sweden, Stockholm
Here is my mute relay story: http://forum.beoworld.org/forums/t/921.aspx
Fixer
Fixer replied on Wed, Apr 25 2012 6:57 PM
Thanks for the post funny as I was reading it before but didn't put 2 & 2 together that it may be the same issue.
joeyboygolf
Verified by Fixer
Regards Graham
tournedos
Finland
Verified by Fixer
Fixer:
--mika
Søren Mexico
Mexico City
tournedos:
And dont buy some cheap sh1t, buy good quality tools, they last for years and has the right dimensions.
Fixer
Fixer replied on Wed, Apr 25 2012 7:14 PM
Thanks all for the prompt response, my thoughts exactly on the philips screwdriver, there was so little left of the head I had to cut in a slot to use a flathead to undo them.  I can at least source some on the internet now with the information you have given me.
I will have a good look through the other post and get to work on the mute relay.
Thanks again.
Søren Mexico
Mexico City
I scrapped a Panasonic Flat screen, I opened it and took out all the screws I could easily get at, a lot of M3 and M4 Philips head, and a lot of washers.
joeyboygolf
Fixer:
Yes , as the mute relay only works on the Spk1 sockets.
Regards Graham
tournedos
Finland
Fixer:
The funny thing is that they usually have slotting for a flathead if one bothers to look before mauling them with a Phillips Smile
Not in all cases, though. If you intend to work more on B&O kit from those days and later, get a selection of three Torx drivers: T10, T15 and T20. They'll be enough for most, if not all needs.
I greatly prefer Torx over Phillips for every use.
--mika
Fixer
Fixer replied on Wed, Apr 25 2012 7:56 PM
Thanks but I have managed to locate a pack of 100 at £0.95! I cant go wrong at that price.
Fixer
Fixer replied on Wed, Apr 25 2012 8:02 PM
Yes I thought they did but these didn't. There was basically just a smooth bare metal recess where the grip used to be! God knows who decided to have a peek inside previously and what they did.
Page 1 of 1 (13 items) | RSS
