Beovision AV9000 compatibility
Not Answered This post has 0 verified answers | 6 Replies | 0 Followers
Graham1982
Graham1982 posted on Fri, Feb 28 2014 5:42 PM
Hi all:
As you maybe aware I had a Beovision AV9000 which was working then the tube died. I have now sourced a screen only which I hope I can just transplant onto the base of the broken TV.
My question is, is this possible or are these TVs paired with their bases and as such the parts cannot be interchanged?
Graham
kallasr
Germany
I did this before with success.
But no idea if this will work always (software versions etc.)
Give i a try!
Ralf
Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 8000 (Fronts and Rears) and Beolab 2. Screen: Panasonic TX-P65STW60
Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all White)
Graham1982
Hi Ralf:
If it throws a software error do you know of a way to fix this or is this an open the TV up kind of job to flash new software?
Graham
kallasr
Germany
Sorry, no idea.
I believe it will work for you, too.
Ralf
Graham1982
Hi Ralf:
Thanks - will probably give it a go. Just don't want to end up with two broken/not working TVs in the house - they are pretty big.
Beobuddy
Utrecht, The Netherlands
The AV9000 is based on the MX7000.
Tubes can ge placed with the same numbers on the back of the tube.
Software can't be flashed. It's an hardware version. But not needed.
Graham1982
Hi:
Thanks, I am not planning on replacing the tube - I just want to place a complete TV unit (the blue bit) onto my speaker base. Is that possible?
Page 1 of 1 (7 items) | RSS
