BeoPlay V1: Whats in the Box?
Not Answered This post has 0 verified answers | 35 Replies | 3 Followers
Lenny
Germany
Lenny posted on Wed, Jan 22 2014 8:29 AM
Hi there!
Can anybody tell me if you get the wireless antenna and the PUC Cable with your V1 in the Box or do I have to buy them separately?
Lenny
hfat
Vienna, Austria
hfat replied on Wed, Jan 22 2014 9:05 AM
Hi Lenny,
The wireless antenna is in the box. The PUC cable you have to buy separately.
hfat
Lenny
Germany
Lenny replied on Wed, Jan 22 2014 9:20 AM
OK. That sounds OK. Does anybody know if this PUC Cable is a standard product or if they have to order it?
madskp
Denmark
madskp replied on Wed, Jan 22 2014 10:08 AM
Mine came with a double PUC cable for two external units. I told the dealer I had an Apple TV before they delivered the tv so it might be because of that
w5bno123
London
w5bno123 replied on Wed, Jan 22 2014 10:48 AM
hfat:
Hi Lenny,
hfat
Hi Lenny
All BeoVision's are now supplied with a single PUC cable. If you need to control more products then ask your dealer and this can be supplied as an accessory.
Lenny
Germany
Lenny replied on Wed, Jan 22 2014 10:54 AM
Therefore, my new V1 which will be delivered on Friday, should have a single PUC cable. Which is enough. I just want to connect an Apple TV
Millemissen
Flensborg, Denmark
Mine (from November 2013) came with the Antenna (which I don't need) in the box.
My dealer told me that this is/was about to change - you will have to order that seperately in the future.
And it came with a single-wired PUC cable.
As I needed 2xPUC, I got an additional double-wired from the dealer.
There are two PUC ports on the V1 (32"), so you need at least one double-wired cable, if you want to control more than two external devices.
Lenny
Germany
Lenny replied on Wed, Jan 22 2014 11:26 AM
Lets see if the wireless Antenna is included or not... I will report as soon as I have my V1 at home on Friday
Alex
Essex
Alex replied on Wed, Jan 22 2014 12:51 PM
Mine came with both if you need a double PUC I'm sure you dealer will send you one
Simonbeo
Ours came with a Tyko antenna which I found after the installer left and I called the store . They said they didn't know what it's for and it must be the installers and he forgot it. Could this be the wireless antenna ?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Lenny
Germany
Lenny replied on Wed, Jan 22 2014 8:21 PM
It looks like the one in this auction:
http://www.ebay.de/itm/Bang-Olufsen-BeoPlay-V1-32-V1-40-Wireless-Antenne-NEU-Originalverpackt-/121255719852?pt=DE_TV_Video_Audio_Sonstige&hash=item1c3b6773ac
Simonbeo
Yes, that's the antenna . What will it do for us. Look forward to learning.
Millemissen
Flensborg, Denmark
Simonbeo:
How could rhat possibly be overlooked in the box?
What kind of installers were they - if they did not know of the antenna, and what that is for?
Just wondering Confused
Lenny
Germany
Lenny replied on Wed, Jan 22 2014 9:28 PM
Simonbeo:
You need this antenna to connect your V1 to your Wireless Network (WiFi).
Simonbeo
The V1 is directly connected to the router, so that must be why the antenna was not needed? The installers were from the B&O store.
Page 1 of 3 (36 items) 1 2 3 Next > | RSS
