Beoworld app
This post has 256 Replies | 4 Followers
Kiran
UK
Posts 1,011
Kiran replied on Thu, Sep 20 2018 10:16 AM
Changed it just now...
Logged out of the app and logged back in...
Still have the same problem...
Regards
Kiran
Born in NL; I ride ML
BL5
Flensburg, Germany
Posts 11
BL5 replied on Thu, Sep 20 2018 10:23 AM
Hi Kiran,
you have to choose the very first entry in the list Wink ...
In use: BV Avant 55 NG, BS Moment, 2x BL 5, A 6, A 2, H 6 MK I, H 7, A 8 (Earphones)
Currently not in use: BV 7-32 MK I, HDR 2, BS 9000 MK III, Serenata, 2x BeoCom 3
Kiran
UK
Posts 1,011
Kiran replied on Thu, Sep 20 2018 10:41 AM
BL5:
Hi Kiran,
you have to choose the very first entry in the list ...
You legend!
All working well now.
Thank you!
Regards
Kiran
BL5
Flensburg, Germany
Posts 11
BL5 replied on Thu, Sep 20 2018 10:59 AM
No problem, had the same issue in the past ...
Saint Beogrowler
Saint Paul
Posts 735
Thanks Phil for the optimized app update!
OlivierC
Posts 29
OlivierC replied on Fri, Sep 21 2018 4:56 PM
I can confirm I’m using the right credential.
i can login from the website via iPhone (this is from where I’m now posting), not from the app, despite having upgraded to the latest release of iOS and app. 🙁
Cheers.
Olivier
Kiran
UK
Posts 1,011
Kiran replied on Sat, Sep 22 2018 9:42 AM
Try this...
Delete the app and all related data on the phone...
Then go back to the app store and install a fresh version of the app...
Regards
Kiran
PhilLondon
London
Posts 3,607
Make sure you login with your user name, not your display name. The user name is case sensitive.
Beoworld app with direct photo upload and emoticons. Other apps: ConsltThe Story Mouse
OlivierC
Posts 29
OlivierC replied on Sun, Sep 23 2018 12:16 AM
Kiran, I have cancelled and reinstalled the app (not sure on how to cancel the remaining data from the iPhone) but it still doesn’t work.
Phil, I have tried with both my sign-in name and email address, none of these options seems to work.
Cheers.
Olivier
Kiran
UK
Posts 1,011
Kiran replied on Sun, Sep 23 2018 9:20 AM
I don’t know what else to say mate...
This is strange...
I’ve never had login issues... only the dates were not showing properly until recently...
Regards
Kiran
PhilLondon
London
Posts 3,607
If you want to DM me your login details, and I'll test it in my debugger.
Philippe
PhilLondon
London
Posts 3,607
I found the issue... the character "+" in your password isn't supported properly by the app.
I'll fix this issue in a future version, but in the meantime you can either update your password on the site (to remove the +), or you can type those 3 characters %2B instead on the + character when you login using the app.
p.
OlivierC
Posts 29
OlivierC replied on Tue, Sep 25 2018 12:00 PM
Hi Phil, thank you for sorting this issue!
Now I feel a bit embarrassed but I don't know where to change the login password… Embarrassed
Olivier
elephant
AU
Posts 8,218
OlivierC:
Olivier
Good question.
I think it used to be easy however our webmaster (Keith) has tightened it up.
You sign on via the browser; select edit profile link; select sign on details tab; and you land here ... what you do next ? I don’t know anymore !
BeoNut since '75
elephant
AU
Posts 8,218
PS maybe there is an FAQ that has the answer.
BeoNut since '75
Keith Saunders
Little Ann, Hampshire, United Kingdom
Posts 5,162
elephant:
OlivierC:
Olivier
Good question.
To change your Beoworld Account password go to https://portal.beoworld.org
You could also just use the link under the David Lewis banner above which appears on EVERY forum page.
Regards Keith....
elephant
AU
Posts 8,218
Thanks Keith
BeoNut since '75
Page 7 of 7 (257 items) « First ... < Previous 3 4 5 6 7 | RSS
