BV7 Projector
This post has 9 Replies | 2 Followers
Scott Needham
Paris, France
Posts 217
Scott Needham Posted: Fri, Jan 3 2014 2:34 PM
I am looking into a projector for my living room. I currently have a BV7-40. I would love to have some feedback from the forum concerning projectors and screens.
Thank you in advance for your good ideas !
- Scott
georgey007
Posts 74
Hi
I recently bought a used samsung sp-a600b wich is in the puc table and is verry great
Bv7Mk3
uk
Posts 781
Bv7Mk3 replied on Sat, Jan 4 2014 12:43 AM
Scot which Bv 7-40 model do you have?
I'm running a Jvc hd 1 1080p projector on a. Bv 7-55 mk 2 works great!
This is not the first Bv tv that I have used the projector on.Have used it on a bv7-40 mk3 also 7-55 mk 1. No problem.
Scott Needham
Paris, France
Posts 217
hello again,
i have a bv7-40 mk5.
i looked through the puc table and i did not see many projectors. where are you getting codes, from dealers ?
- scott
BeoMegaMan
Posts 598
I'd say if you have 5-6K to spend I would look at the new Sim Cube or the JVC Reference series. For less than 6k it doesn't get much better in my opinion.
Ah, you know... A little B&O here, a little there
quader
Posts 105
quader replied on Sat, Jan 4 2014 4:50 PM
Hi
I am using an Optoma HD65 on my BV7 MK3 with 2 speaker setups as the screen is on another wall
well satisfied with it
Seanie_230
UK
Posts 2,234
Hi there
I have the BV7 MK4 and I am also using the Optoma HD65 beemer without PUC. I use a lintronic -238 to activate everything when the bins on the BV7 cinema output are activated.
I also use a motorised screen from Optoma its their Panoview.
My setup is excellent and cost a little over £500.
Screen drops down in front of the TV to just over the beolab speaker so I keep the same speaker config.
Good Luck its well worth it.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
lolantana
Posts 1
I got a Sony VPL-VW1100ES Native 4K Projector last December to be a gift for my family, cause I planed to watch movie with my family on the Christmas night with the feeling of cinema. It worked very well and I set it up in my living room. The one I got with the size of 29.1*26.8*13.4, the contrast radio of 1000000:1 and the brightness of 2000 lumens. Actually you`d better pay for the one you like after taking refer to the reviews or buying guide of projectors. If you can get a 4k projector the article of comparison of 4k projector here is what I recommend to you highly.
->> https://www.cfone.net/5-comparison-for-4k-projector-on-amazon-com.html
harryjosh
Posts 1
harryjosh replied on Tue, Apr 30 2019 10:21 AM
I'm one of those people who just sees blurred images, 3D is not for me.
4k projectors on the other hand is outstanding on Optoma UHD51A projector. It was $1,709 at one point on Amazon. I watched planet earth 2 and it was quite an experience. Make sure you get a good pulldown screen.
beojeff
USA
Posts 1,953
beojeff replied on Tue, Apr 30 2019 11:23 AM
georgey007:
Hi
Were you able to get the specific PUC for the sp-a600b model? I have that same projector. A year ago, BeoCare told me that they didn't have the entry for that projector and suggested I used the PUC for another Samsung projector. The problem is that the sp-a600b requires a conformation from you that you do indeed want to power down the projector -- which the other samsung projector does not.
Page 1 of 1 (10 items) | RSS
