Beosound 9000
Not Answered This post has 0 verified answers | 3 Replies | 1 Follower
antspants13
antspants13 posted on Mon, Apr 16 2012 12:49 AM
Hi all,
Sorry posted this in the wrong section previously!
After playing a cd earlier, the carriage/laser dropped suddenly to the base position and wont return to the home/top position. Is this a common problem? will it be easy to get repaired? expensive?
Stan
Chicago-area USA
Stan replied on Mon, Apr 16 2012 3:52 AM
It might be as simple as cleaning the finger protection sensors - look for two small, clear things that stick out from opposite ends of the metal surface near the open side of the glass door.  Wipe gently with a clean, soft cloth, and that could be it.
Stan
antspants13
Stan,
Your a star, I now feel really stupid as that did the trick, so  pleased
Very attentive cleaning from now on!!!
Many thanks  :D
Jeff
USA
Silver Member
Jeff replied on Tue, Apr 17 2012 1:40 AM
Mine did the same thing a few years ago. Unfortunately that was before I knew about Beoworld but after the local store closed, so I wound up taking it 60 miles to a repair shop to find out it just needed the prisms cleaned. Super Angry
Jeff
Page 1 of 1 (4 items) | RSS
