Beogram CD 4500 no Sound
This post has 9 Replies | 2 Followers
ArcheNoah
Posts 37
ArcheNoah Posted: Sat, Apr 14 2012 8:18 AM
Dear enthusiasts
I have a Beogram CD 4500 which plays, spinns the CD. But unfortunately I don't get any sound.
Can someone give me a hint where a problem could be?
Best regards
Noah
kokomo
Spain
Posts 206
kokomo replied on Sat, Apr 14 2012 8:40 AM
Before investigating any likely problem from the unit itself, are you sure the lead to the amp' is not the source of the problem?
ArcheNoah
Posts 37
ArcheNoah replied on Sun, Apr 15 2012 6:57 AM
I was thinking that too. But how can I test the lead? I first thought that there are some broken soldering joints, but I could not find any.
kokomo
Spain
Posts 206
kokomo replied on Sun, Apr 15 2012 8:11 AM
I think the only way is to buy another lead. Worth it I think to find out where the real fault may be. I assume you don't have anything else connected, like the 4500 cassette deck? You could use that lead.
Evan
Germany
Posts 3,581
Evan replied on Sun, Apr 15 2012 3:11 PM
Testing the leads will be difficult on the 4500 sources as they are not interchangeable.
Beo4 'til I die!
Søren Mexico
Mexico City
Posts 6,290
As you was checking for broken and bad soldering, you must have had the CD open. Now unplug the power supply, with a multimeter check that each cable strand has connection to a pin on the plug.
To which amp is the CD connected ?
ArcheNoah
Posts 37
ArcheNoah replied on Wed, Apr 18 2012 7:50 AM
It is connected to a Beomaster 7000.
Never did this before with a multimeter.Wink But I bought one yesterday. Big Smile
I tried to test the cable. But I am not sure if I did it correct. The multimeter shows different figures at each pin!
Søren Mexico
Mexico City
Posts 6,290
If your meter shows different values it only natural, it measures the resistance between the pins. If measuring from where the cable is  soldered in the CD to each pin, one of the pins will show 0.0 ohms or 0.1 ohm, make a note, then change to next pin/solder point, and if all pins/solder points shows 0.0 ohms your cable is OK, but if one of them shows mega ohms the strand is broken, so each soldered cable strand must have a 0.0 ohm to one pin, there may be less cable strands than pins, I dont know your model.
Søren Mexico
Mexico City
Posts 6,290
Check the pinout here
Dillen
Copenhagen / Denmark
Posts 10,846
Dillen replied on Wed, Apr 18 2012 9:07 AM
Check that the CD player is connected to the correct socket in the Beomaster.
Page 1 of 1 (10 items) | RSS
