Beolit 12 and standby
Not Answered This post has 0 verified answers | 9 Replies | 2 Followers
forthmedia
forthmedia posted on Mon, Apr 9 2012 6:53 PM
I recently purchased a Beolit 12, and while I'm pleased with it's performance, it seems to go into standby mode after about 15mins of non-play even when connected to a power source. This is rather irritating, because it means attending the machine to switch it on, and then wait for it to acquire the wi-fi signal. Not ideal if you are in bed on a cold morning
bayerische
Ekenäs, Finland
Really?
I'm not familiar with the Beolit, haven't even seen it, should keep the wifi connection if connected to mains IMHO.
Too long to list....
linder
United States
forthmedia:
I like my Beolit 12 also and am very pleased.  I noticed that in standby after about 15 minutes, wifi does disconnect.  I assumed it was in the setup somewhere and for me it was acceptable.  I usually charge my iPhone and iPad using the Beolit 12 which makes it a docking station.  No problems in docking mode.  However I am going to review the instructions.  There are times when I also prefer Beolit 12 not disconnect from wifi.
w5bno123
London
Dear all
There will be a sw patch in the very near future to sort out the standby issue!
You can once connected to the network use the new Beolit app to update the unit via your iPhone
Regards
Stuart
mr_anders_son
sweden
New firmware out now!
Update your Beolit App!!
BeoVision Eclipse 55"...BeoLab 18 as FRONT....BeoLab 4000 as REAR....BL19 SUB....BV5 HD....Beoplay V1-40....BC6-26....Beosound 9000....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H8....H6 90´s Rose Gold edt....Form 1....U70...
forthmedia
Thanks! I'll try it as soon as I get a chance
travellers4fun
I just got a Beolit 12 and so far am very pleased with it. However I have the same problem. Software is version 1.02.12 which seems to be the latest. It does go into sleep mode when not used, and simply disappears from the WiFi. Unlike the PlayMaker (which I have connected with a set of Beolab 6000) it cannot wake from WiFi signals. DOes anyone have any info to share, any advanced settings I don't know of. I'm quite unhappy about this. Thanks.
leosgonewild
Helsinki, Finland
I got my Beolit 12 a few weeks ago. Updated it to latest software/firmware.
It is connected to a powersource and works fine. But when I return home the following happens:
-I swipe upwards on the iPhone and choose "Beolit 12" as airplay speaker
-It gets marked with a "V", then nothing happens for a while
-The "V" shows up next to "iPhone"
I can play through my other airplay devices without problems when returning home.
Anybody experienced this and knows a fix, or should I try to return it to the store?
koning
holland
With bluetooth 4.0 no wifi dropouts
BeoBoy68
FRANCE
@ travellers4fun
The product will automatically turn off after few minutes if it does not receive a wifi signal.
It is to protect the life of the battery.
If you use the Beolit 12 with a power cord, it don't turn off. Yes - thumbs up
Page 1 of 1 (10 items) | RSS
