Beogram 8000
Answered (Verified) This post has 1 verified answer | 40 Replies | 2 Followers
Orava
Finland
Orava posted on Thu, Oct 17 2013 6:24 PM
Well, hope not beging of WW3, but BG8000 thread
Startpoint
 soon...:
Hey, look! No tools! Yet
Orava
Finland
Answered (Verified) Orava replied on Wed, Oct 30 2013 2:50 PM
Verified by Orava
And here she is, playing happily Lee Clayton.
Orava
Finland
Orava replied on Thu, Oct 17 2013 6:27 PM
Nasty suprise if plugged in. Loose metalplate, whats it for...??
No supporting rod like in 59XX series
But luckily I have Europa
How to disasseble tis...
and tat....
Orava
Finland
Orava replied on Thu, Oct 17 2013 6:29 PM
Ah, transformer goes up, and board is off the hooks.
Orava
Finland
Orava replied on Thu, Oct 17 2013 6:30 PM
And by one screw...
Orava
Finland
Orava replied on Fri, Oct 18 2013 7:01 AM
This was a bit difficult
But it gave up
Smells like recapping
Orava
Finland
Orava replied on Fri, Oct 18 2013 7:04 AM
All stripped
Not burnt, but dusty
Orava
Finland
Orava replied on Fri, Oct 18 2013 7:07 AM
Intresting switch in panel
Remains me about BM1900 series volume control, same designer?
Orava
Finland
Orava replied on Fri, Oct 18 2013 7:11 AM
Compared to 59XX, this is almost like heavy industry
And downunder
Indicator ready to rebulbed
I wonder why R1 is here called "photo element" and elsewhere "photoresistor"? What is the difference between?
Orava
Finland
Orava replied on Fri, Oct 18 2013 7:13 AM
Recapped
Orava
Finland
Orava replied on Fri, Oct 18 2013 7:16 AM
Ouch, indicator signal dissapears to somewhere here
Changed transistor, and signal comes through and platter ribs are seen
Still it wont regonice edge of disk, what is wrong? Confused
chartz
Burgundy, France
chartz replied on Fri, Oct 18 2013 8:55 PM
Could you be more specific? Does it go all the way to the end of side? What does it do then?
By the way, have you yet checked this setting?
Jacques
Orava
Finland
Orava replied on Mon, Oct 21 2013 5:03 PM
Today back by the bench again.
Hi Jaques. Yes I did adjust them.
If I just ress play, it goes right to the end, and I bet it likes to go over if could. However, if there is a singe on platter and go back to rib area, press play, it founds edge allright.
Thinking, thinking....
chartz
Burgundy, France
chartz replied on Mon, Oct 21 2013 5:46 PM
Okay but does it play the EP disc?
Is the SO switch present and correctly mounted?
Does the sensor counter circuit work? The IR diode is fragile and can go belly-up. If the processor doesn't see a certain number of pulses (the Beogram 8000 counts everything!) from the arm carriage screw tacho (motor side) it won't stop. Check this circuit.
The platter ribs are there for no disc or EP/45RPM only so that works.
What I did:
Jacques
Orava
Finland
Orava replied on Mon, Oct 21 2013 7:09 PM
Oh yes, it does play small ones.(singles)
I check that counter sensor works, but havent check it any deeper, will check tomorrow.
SO switch? Switch Off? It works.
Mechanically this looks more simple if compared to 59xx, but no wonder if it counts it's way.
Orava
Finland
Orava replied on Tue, Oct 22 2013 7:20 AM
Just tought, is this working by contrast difference and thus by edge, not by level, of signal from indicator arm? If so, maybe it just do not get clear enough signal without topplate?
Page 1 of 3 (41 items) 1 2 3 Next > | RSS
