Beosound 5 Encore Wi fi connection issue
Answered (Verified) This post has 1 verified answer | 8 Replies | 2 Followers
Paul cheacker
Spain
Paul cheacker posted on Tue, Sep 24 2013 8:51 PM
I recently installed an epsom wi fi printer, on installing it I made a change on my router security. When switching on the BOS5E obviously it would not connect. Now however when I use it to search for the wi fi it doesnt pick it up. So I have entered the router id and the passwords and it searches for it but still does not pick it up for connection. Anyone have any idea how I can solve this.
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
kokomo
Spain
Answered (Verified) kokomo replied on Sat, Sep 28 2013 1:17 PM
Verified by Paul cheacker
Disclaimer first, I know nothing out the Beosound 5. However, have you tried switching off  the printer completely? Does the beo5 now connect to wifi? If not try re-booting the router. Then if no luck go into wireless router settings and switch to no security encryption, then see if BeoSound connects. If it does, at least you've then narrowed it down to your router's security settings.
Have you changed router settings to a type of encryption that the Beosound does not recognise - eg WEP, WAP, WPA etc?
Have you ensured the router's and Beosound wifi settings are exactly the same?
Apologies if this reply is a bit simplistic.
Finally, why did you change your security settings in the first place? Was this necessary to 'connect' the printer?
Paul cheacker
Spain
Does anyone at all have any ideas please, I am getting BS5E withdrawal symptoms being without it now for 2 days.
scottyltd
Hello there,
Seems as this is a simple case of either router settings which have changed or IP address. Either the printer has turned off UPNP or the printer has the same IP as BS5E. If UPNP is off turn it back on in router settings. If IP address issue change BS5E ip address.
If you are not sure how to change these settings, just contact local dealer with these 2 suggestions.
kokomo
Spain
Millemissen
Flensborg, Denmark
Hi applemac,
I made a change on my router security "
Could you be more specific - what did you change?
Be sure that DLNA is enabled in the router settings, and that the (DLNA)server on the network is running.
N.B. Two devices with the same ip-adress on the same network is not possible.
Seems to me to be a port-issue.
Do you have a person with network-skills in your neighborhood?
Paul cheacker
Spain
Hi I made a mistake and change the security setting to connect the printer when I did not need to, however following your advice and switching of the security of the router allowed the BSE5 to connect to the router viua wi fi. However I cant leave the wi fi on without security.
Paul cheacker
Spain
Koko,
thanks you advice actually solved my problem, firstly I turn off the security on my router this allowed the BOS5E to connect to the router, after it obtainned a IP address etc I then switched the security setting back on my router. Turned off the BOS5E and turned it back on and it still connects.
Thanks for all the help
addi987
Actually, the same issue I have also faced with my canon printer that time canon support helped me a lot to resolve the issue and also advice some very essential things regarding wi-fi printer which is important to know to make your printer long lasting.
emniclap
Suggested by emniclap
Printer is a common problem that usually occurs while printing on a regular basis. Due to having low internet connection on your operating system, such an issue can be arisen brother printer in error state. You may start wandering for the technical support of your Why Is My Brother Printer Offline related type of query. Despite of wasting your precious time, you should contact to the certified technicians via calling helpline number.
Page 1 of 1 (9 items) | RSS
