Beovision 11
Answered (Not Verified) This post has 0 verified answers | 172 Replies | 7 Followers
scognamiglio
scognamiglio posted on Fri, Apr 6 2012 6:55 PM
Do you have any news on the new beovision 11?
I just know 5 hdmi, a slot for the apple tv and some smart
Tv Functions... I saw a black and white picture but the design wasn't clear..
Raeuber
Germany
Raeuber replied on Thu, Oct 11 2012 12:05 PM
stefan:
mr_anders_son:
How to connect link-Tv ?
For videolink Beo recommend the HDMI Matrix.....no built in RF modulator...
No Cinema function.....
No Timer function...
Stefan
Hi Steffan,
ok, video distribution will be possible with a costly and complex HDMI Matrix (also with BV 10 yet), but not with the new ML/NL converter.
But take a look into "getting started", connection panels (page 24):
MONITOR CONTROL: for future use
CTRL (1-2): for future use
EXT.IR: for future use
Probably some desired features will be available in future: video distribution (in HD), cinema funktion...
Regards
Räuber
Vienna
make an educated guess
Vienna replied on Thu, Oct 11 2012 4:26 PM
At the moment a BV11 supports just V.OPT 1 / 2 /4
V.OPT 5 / 6, needed for "Link Rooms" are currently not supported.
Therefore, at the moment a BV 11 can either be used as a "Video Master"
(connected via NL/ML-Converter to an existing MasterLink setup)
or as a "Stand Alone Unit" without ML integration.
Video distribution from "centralised" sources via Atlona Matrix does not need ML ...
IngvarW
Sweden
My 10-46 distribute video to my MX4002 without any extra boxes. Brgds Ingvar
Current; Beosound 2, BV Horizon 48,  2*BL3, BL11, Beolit 12, Beolit 15, Beoplay P6, Beoplay A9, Beoplay H9i
Earlier; BV 10-46, 2*BL3, BM5/BS5, BS9000, BL8000, BV7-32, MX7000, Beoport, Beocord 8000, MX4002, BL2000, Beocom1, Beotalk1200
Vienna
Vienna replied on Thu, Oct 11 2012 4:59 PM
Of course a BV 10 offers this (in standard definition)  - but that's
not any longer possible using a BV11 ...
Whitetail
Hamburg
Hi
i am too very much interested in buying the bv11 provided they re- implement the video / projector out feature like on bv7 for real home cinema. does anybody know why b&o omitted this great feature, and whether / when they plan to install it again - perhaps on those "for future use" sockets?
Whitetail
Vienna
Vienna replied on Mon, Nov 26 2012 8:47 AM
Whitetail:
...when they plan to install it again - perhaps on those "for future use" sockets?
Welcome to the forum.
Let's hope B&O is able to implement HDBaseT to the new video engine - would solve the projector issue and
make HD-video distribution possible.
Raeuber
Germany
Yes, Vienna, HDbaseT is exactly what we need on BV 11 and all Beovisions to come in future because of the lack of masterlink!
/Räuber
elephant
AU
Came across this FlatPanels review via Peter Pans thread ... except the Danish article had a broken link to the English translation, so I did a bit of research and found the correct article -- enjoy:
http://flatpanelshd.com/review.php?subaction=showfull&id=1354451016 <= PS updated in November after this thread went to sleep in October
You might also want to check their CES 2014 highlights
BeoNut since '75
Page 12 of 12 (173 items) « First ... < Previous 8 9 10 11 12 | RSS
