beomaster 5000: noise in loudspeaker when shut off
Not Answered This post has 0 verified answers | 1 Reply | 1 Follower
tiwang
Denmark
tiwang posted on Mon, Sep 9 2013 9:09 PM
hi out there
I have a old beomaster 5000 (the first computer controlled version - Square with alu) - when it is shut off there is still some idle noise in the loudspeakers from some current leak - some ideas for from where that leak can come?
best regards /ti
Dillen
Copenhagen / Denmark
Dillen replied on Mon, Sep 9 2013 10:10 PM
Off with the bottom plate and check the solder joints on the power supply relais.
If the relay coil is never energized, the amplifiers are always powered (not good for your electric bill).
Page 1 of 1 (2 items) | RSS
