Beosound 5/Beomaster 5 connects to Beovision 7-40 mark 6
Not Answered This post has 0 verified answers | 4 Replies | 2 Followers
Sacha88
Sacha88 posted on Mon, Sep 9 2013 1:49 PM
Have just bought a used Beosound/Beomaster 5 system and trying to wire up to my TV. Have connected via a master link cable and the Beosound 5 and Beomaster 5 are connected. Beo 4 remote works well enough, but stuck. Do I need to connect anything else to the TV or do I need to reprogramme the Beosound 5?
Help please!
Razlaw
Razlaw replied on Tue, Sep 10 2013 10:32 PM
I have a Beosound 5 but don't know that I know enough about it to help you. Could you clarify what the problem is and I will try if I can to help.
Sacha88
Sacha88 replied on Tue, Sep 10 2013 10:57 PM
I've a master link going into the TV from the BeoMaster 5. All the leads going from the BeoSound 5 to the BeoMaster 5. The settings on the BeoSound 5 for NMusic are via A.Mem on the Beo4 remote. However I can't seem to get any sound? Perhaps it's the settings on the BeoSound 5?
Thanks for your help, Best,  Sacha.
Emil
Emil replied on Tue, Sep 10 2013 11:12 PM
Have you checked the option programming of the tv? Might be that you have to press "av" + a.mem.
Millemissen
Flensborg, Denmark
ONLINE
You have no BeoLabs' on the BM/BS5 - right?
You want to play through the BV?
Check page 28 of the Userguide for BeoSound5 avaible on the B&O homepage:
http://m.bang-olufsen.com/en/Sound/Sound-systems/Beosound5/user-guides
http://www.bang-olufsen.com/en/customer-service/product-support/sound/sound-systems/beosound-5
Settings for 'AM options.
Greetings Millemissen
Page 1 of 1 (5 items) | RSS
