Raspberry PI as media center steered by Beolink 4
Not Answered This post has 0 verified answers | 21 Replies | 5 Followers
Alsfeld
Alsfeld posted on Sun, Sep 1 2013 8:27 PM
I am using a Raspberry PI with RaspBMC (http://www.raspbmc.com/) as media center with XBMC controlled by my Beolink 4.
(1) In order to realize this solution, I am using a TSOP7000 miniature infrared receiver of 455kHz (http://darisusgmbh.de/shop/product_info.php/products_id/34359/language/de)
(2) I followed the instructions on http://forum.stmlabs.com/showthread.php?tid=5549 Step 3 to Step 5.
(3) Unfortunately I had some difficulties with the Beolink 4, since not all selected keys trained worked in the beginning. In these cases I exchanged the recorded codes and used the codes from the document "Beo4" on page http://lirc.sourceforge.net/remotes/bang&olufsen/.
MJBeo
Netherlands
MJBeo replied on Fri, Sep 6 2013 5:08 PM
Cool! Will this work with beolink 1000? And this IR receiver is only 3€?
I will try this, thanks
Beosystem 5500 + Playmaker MKI + RL60.2 / MCL2 A + RL35      BV7-32 MKIII + Raspberry Pi3 + Lintronic -238 + MCL2P & CX50 / Cona     4 link rooms with MCL2 A / MCL2 A/V + MCL2P  + CX100 / CX50 / Grundig 210a     Various Vintage restore objects
Rivenflush
Gothenburg
This looks cool!
Is XBMC running smoothly? What skin do you use (Aeon?)?
What model of the Raspberry PI do you have (A or B)?
Br
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Beobuddy
Utrecht, The Netherlands
I have the B version and it works very slow. I've tried several XMBC images, but stopped experimenting due to the amount of irritation.
For the record, I stream video from a NAS.
Alsfeld
@MJBeo
Yes, you only need the TSOP7000 IR receiver for ~3 Euros and some cable to connect it to GPIO.
It should work with the beolink 1000, too.
I only recorded the most important keys, see attached lircd.conf file. For more complicated tasks I anyway use a keyboard.
@Rivenflush
It's running OK for accessing and streaming video, music and picture files from NAS (Synology) in my case. Live TV via HDHomeRun Internet Tuner + NAS + DVBLink runs perfectly, too. But normally I use my NAS as video recorder and watch it later via raspberry on my TV.
Originally I used the default skin "Confluence", but I changed to "Quartz" and overclocked my Raspbmc to increase the performance. I am using Raspberry Model B.
Alsfeld
I had some problems with the TSOP7000, not reacting always to my Beolink 4 (like loose contact). The TSOP4838 (for 38 kHz) which I connected via PUC to my Beovision 9, on the other hand worked smooth form the beginning. After added a capacitor C1 - 4.7µF, a diode D1 - 1N4148 and a resistor R1 - 4k7 like this:
+-----------------------+ 3                                  | /|   3
|                     + +----------+-------------------+-----|< |-o VS
|      ______________   |        -----                 |    D1(1N4148)
|     \______________ - +----------+-------o GND      | |
|                       | 2     C1(4.7µF)    2         |
|               data -> +------------------------------+----------o OUT
+-----------------------+ 1                          R1(4k7)        1
The TSOP700 works smooth and reliable with the Beolink 4(see http://www.lirc.org/receivers.html, too).
But still I have two questions:
1)     Is there somebody who can explain, why I need an C1 and R1 for the TSOP7000 to work smooth but not for the TSOP4838?
2)     On http://lirc.sourceforge.net/remotes/bang&olufsen/ you find a lirc.conf file for the Beolink 4. I used the old one, with the following format per Key:
          name KEY_UP
              200    3125     200    3125     200   15625
              200    3125     200    6250     200    6250
              200    6250     200    6250     200    6250
              200    9375     200    6250     200    6250
              200    6250     200    3125     200   12500
              200
The “new” format (somebody changed the file on 01-May-2014)
    name KEY_UP
          KEY_0                    3125                      #  Was: 200
          KEY_0                    6250                      #  Was: 200
          KEY_0                    9375                      #  Was: 200
          KEY_0                     #  Was: 200
Does not work on my Raspberry PI setup. In case somebody is looking for the old file, I have downloaded and can provided it.
Alex
Essex
Alex replied on Sun, Apr 5 2015 12:06 PM
for my Avant 55" i use a MINIX X7 system,
They are a great media system android based and also has its own version of XMBC which runs really smoothly
also B&O have the PUC to control it so controlling it via the B&O remote was easy!
tournedos
Finland
Alsfeld:
These 3-pin IR receiver ICs are quite sensitive components. The C and R are there to filter & suppress power supply interference. Even if you didn't find the *38 to necessarily need them, it probably works more reliably and is more sensitive with them.
The last time I looked into the "Beo 4" entry in LIRC repositories some years ago, the config file was far from complete and seemed to have been captured with unstable and/or incorrect timing parameters so it didn't need many additional uncertainties to start working erratically. I ended up recapturing it completely from scratch. Unfortunately I don't think I have it left anywhere anymore, since I later abandoned LIRC completely and wrote my own receiver on an Arduino.
Now that my main TV is a Sony, I don't need any direct IR control at all since the RPi + OSMC -combo is controlled directly via HDMI CEC. Unfortunately that also means I need to live with the crappy Sony remote.
--mika
boetter
Sounds lile a fantastic solution! I am ready to buy a Minix for my Beocenter 1, but unable to find any info on B&O compability anywhere. Can you help? Maybe a step-by-step guide on how to set it up?
Purup
Purup replied on Mon, Jun 12 2017 12:47 PM
Hello,
I'm all new to this forum and the Raspberry PI and now my mind is set on controlling some LEDs with my Beolink4.
So far, I have setup a Raspberry Pi Zero with LIRC and connected a TSOP7000 as per your diagram above. By running "mode2 -d /dev/lirc0", I get lot of output when pressing the remote. It looks like:
space 12
space 6056
space 6266
space 75
space 113
space 6072
space 125
space 24
space 2979
space 191
space 12325
...and so on - lots off spaces, very few pulses. Does this looks right? (Occasionally I get output even when I don't press the remote too, mostly spaces between 1 - 25)
I have used irrecord to create the lircd.conf file, but examining the file pulse/space data looks very irregular - not anywhere as neat as your examples above. I have also copy/pasted your KEY_UP values into the lircd.conf file. Regardless, using irw I am not able to detect any button presses.
Any suggestions as to where the problem is would be much appreciated!
Also, if I could have the lircd.conf file you had success using, that would be great. My email is mads@purup.com
Thanks!
samsp
samsp replied on Sat, Apr 6 2019 5:54 AM
did you get this to work with the Beo4?
Purup
Purup replied on Mon, Apr 8 2019 11:18 AM
Unfortunately not. I couldn't find any help or figure it out so I gave up. If you succeed please let me know, thanks.
RaMaBo
near Munich
several years ago i downloaded the 'correct' (= old format) Lirc file from lirc.org.
It's attached  as a zip file containing 'beo4.conf'.
Ralph-Marcus
Purup
Purup replied on Wed, Apr 10 2019 2:41 AM
Thanks. Did you also manage to successfully build a Raspberry PI receiver?
samsp
samsp replied on Fri, Apr 26 2019 7:05 AM
I have been playing with a Raspberry Pi with Lirc, and did not find any success.Sad
However I did see a link to a github repo for BeoMote which is a library for use with an Arduino. The original was designed for a B&O eye, and I am using a TSOP 7000. I have reworked a clone and have it working pretty reliably with an Arduino Uno. The circuit is the same as in this thread, but without the 4k7 resistor. I have it hooked up to the 3.3v and pin 3 of my Uno. Pressing remote buttons will result in translated commands being sent over the serial port. Initially it seemed excessive to use both a Pi and Arduino, but in retrospect it should be more reliable as the Arduino can do the time sensitive pulse processing, leaving the Pi to do other CPU intensive work without having to worry about the remote processing.
My git clone is at https://github.com/samsp99/Beomote. I also added the commands I could find in the BeoRemote One that were not already in the commands enum from Beo 4.
The loop function of the sketch writes the remote data via the USB serial connection. If I have the arduino hooked to a USB port of the Pi, then I can read the data via the USB serial port that is created over the USB connection. It seems like the Pi has the drivers included so it maps the arduino to /dev/ttyUSB0.
I will be hooking this up to OpenHab to control my TV, Receiver, Fire TV, PS4 etc via a combination of HDMI CEC and IP commands (Pioneer). Essentially an overly complex and expensive version of a Logitech Harmony, but with the egonomics of a B&O remote.
Page 1 of 2 (22 items) 1 2 Next > | RSS
