Beomaster 5 advice
Not Answered This post has 0 verified answers | 2 Replies | 2 Followers
ASud
ASud posted on Sun, Sep 1 2013 6:47 PM
Hi All,
Thanks for all the previous expert advice on this forum, I have another problem I need advice again. Beomaster 5 works fine until when I switch it off. The sound stops, for example internet radio, on the head unit/beosound 5 the radio channel is still being shown although there is no sound. I then try to use it again and the only way I can do this is to switch the power off for a prolng period of time. I have had to do this on several occassions.
I have not changed the settings of the Beomaster 5 so how do I fix the problem. Advice really appreciated.
Thanks,
Rasomi
Rasomi replied on Mon, Oct 8 2018 10:01 AM
I have the same problem, beosound works perfectly but after a few seconds the beolab swiths off, I have to reboot to get sound again, when I switch off the beosound, and tur it on again again after a few seconds no sound, hope someone can help me.
Kiran
UK
Kiran replied on Fri, Nov 16 2018 8:34 PM
Do a full on factory hard reset wiping everything. You can find steps to this on the net and I think I found it here in BeoWorld...
Regards
Kiran
Born in NL; I ride ML
Page 1 of 1 (3 items) | RSS
