Beo5/6 with AppleTV
Not Answered This post has 0 verified answers | 4 Replies | 1 Follower
CasperI
CasperI posted on Wed, Apr 4 2012 11:59 AM
Hi.
I have a question for all af you guys using your Beo5/6 with AppleTV.
Since the 2.3 update for the AppleTV was released, it now has a new fancy feature. You can learn the AppleTV to be controlled with 3rd party remotes.
Now, i of course want to use this feature with my new Beo6, so i doesn't have to control my AppleTV2 thru a puc connection (i currently use the AppleTV remote).
BUT i can't get it to work?! Anyone else tried this? .. I can see on the back of the Beo6, that it sends out IR commands, but the AppleTV doesn't react.
I have tried with a remote for a "normal" HiFi system and it works flawless.
Anyone know what might be wrong? -I would really like not to have to set it up by puc, if this is possible
Heribert
Vorarlberg / Austria
B&O Remotes work on a different frequency than others. Beo5 or 6 should be able to do both frequencies. Perhaps this is the key. Just an idea.
BV 11-46  / Beoplay V1 -40 / Apple TV 1+3 / Beosound Essence MK2 / BL3 / 2* BL11 / BL 6000 / BL 12-1 / BL 2000 / 3 * Beo4 /BL Converter 1611
Keith Saunders
Little Ann, Hampshire, United Kingdom
CasperI:
If, what you are saying is that you want the Apple TV to learn the B&O codes from your Beo6 which you currently using to send to your Beovision PUC then you have two issues stopping it working:-
  1. The IR codes being sent to the Beovision are B&O IR codes NOT apple, the PUC in the TV converts the Beo6 B&O IR Codes to Apple codes
  2. Even if the Apple could detect IR codes with a B&O carrier frequency, they would not understand the code
The Apple will ONLY detect standard carrier frequencies which is between 30 KHZ and 80 Khz, but B&O uses 455 Khz
If, for some reason you wish to control the Apple DIRECTLY from the Beo6 not using the PUC converter in your Beovision, then you would need to have a third party XML. You can download an XML for an Apple HERE
Regards Keith....
CasperI
Actually, as i just got my B&O TV (by the way a 7-55, and very happy with it Big Smile) and Beo6, I haven't had the time to set up the puc control, so i just use the Apple remote.
I know how the PUC system works, but i would just favour not using it, if there is another way, so i won't have de short delay.
I did knew that B&O remotes uses a different frequence for IR codes, but i was hoping it would work.
But it sounds great that i should have the opportunity to control it directly from the Beo6 if i fiddle a little with XML. I will definitely give it a go Smile -Thanks
Razlaw
When I connected my first Apple TV a couple years ago, I also noticed it had the learning function. What I did was connect an ir emitter as normal, but then set the puc to another device not Apple Remote. The Apple TV was able to learn the commands for the other device sent thought the ir emitter. In that way I was able to achieve many more commands with both the Beo 4 and Beo 5. For instance I had an individual command assigned to each number, 1-9 as well as other hard buttons.
Page 1 of 1 (5 items) | RSS
