Beocord 5000 Mexico
This post has 4 Replies | 2 Followers
Søren Mexico
Mexico City
Posts 6,387
Søren Mexico Posted: Wed, Apr 4 2012 6:01 AM
Got to the Beocord yesterday, everybody knows how to take of the top cover, so here goes. Take of the command panel, pres the taps. red arrows, to the inside and upwards with a screw driver, then carefully pull the panel up and out.Be careful there is a cable connection below.
Now take off all the red pressure taps, press down with a finger and wiggle a little with a screw driver between tap and chassis, careful, old plastic.
Free the PCB support and raise it to upright pos. both sides, green arrow, free the cables from the clamps, red arrows, pull the plug, blue arrow.
Loosen 2 screws just behind the front panel and tilt it forward to free the PCB.
Now lift up the PCB, careful, its very thin and may brake. Disconnect the command panel plug. When pulling the plugs Laughing place your fingers at the arrows and wiggle it little by little side to side until it comes lose. take out the 2 front panel screws. Pull the 2 plugs for the front panel and take it out.
Panel out, at the arrows you will see some taps that hooks into the chassis, remember these when you put it in again
Raise the panel and secure it with the supports on the back side.
Pull the plugs for the tape unit.
Unscrew the sound cable brackets, and the ground wire behind the power supply PCB
The other side one more ground.
Loosen the cable clamp, blue no arrow Laughing, just bend it with a plier and pull it out from the lower hole, cables free. Pull the 2 plugs, loosen the 2 PCB supports and lift out the PCB.
Unscrew 3 screws and lift out the tape unit.
The drawer motor and drive is secured with 1 screw, take it out and twist with a screw driver, lift out. Mine had no band, and I didn't find rests inside, so someone was here before me.
All out, take out the 4 screws.
Red arrow, this is not a tap, its a highs adjusting shim.
When the roller guides are out, be sure to place the shims so you know to get them back in the same place.
When you take apart the drawer guides, be careful with the E clips, I call them Jesus Christ, because thats what I scream when they fly through the work shop, they seam to have a life of their own.
Clean of all old grease (Iso alcohol) and add new grease, I use silicone grease.
Drawer drive, clean, grease, remember the blade spring pos.
At the tape unit you will find old grease at the red arrows, clean add new grease, I use a pipe cleaner and cotton swabs.
Now change all bands and caps, put it all together again adjust everithing and were done, Big Smile
Will be be back with more.
tournedos
Finland
Posts 7,352
Søren Mexico:
Nice pictures!
--mika
chartz
Burgundy, France
Posts 3,976
chartz replied on Wed, Apr 4 2012 3:15 PM
Nice work as usual.  Cool
This Beocord 5000 is a hidden gem, it is one of my favourite decks. It has the ability to play pre-recordeds very well. It is also an excellent recorder.
I love mine, and so will you Søren.
Jacques
Søren Hammer
Denmark
Posts 953
A very good disassembly guide, Søren. Please copy-paste it into a wiki-entry Smile
The Beocord 5000 is a fine deck, most of the electronics origin from the Beocord 8004. The tape head is nice and large, I quite like it for playing back all kinds of tape.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Dillen
Copenhagen / Denmark
Posts 12,331
Dillen replied on Wed, Apr 4 2012 5:53 PM
Søren Hammer:
...most of the electronics origin from the Beocord 8004.
What ?
Page 1 of 1 (5 items) | RSS
