Bs7000-bv8-40 problem
Not Answered This post has 0 verified answers | 21 Replies | 1 Follower
André S
Roskilde
André S posted on Sun, Aug 18 2013 11:59 AM
Hey all :-)
i have my Bs7000 connectet to my bv8-40 with helt from the 1611 converter.
The problem os that when i press CD one the beo4 my bv turns one and only my bv and not the bs7000
then the speakers turns one but only a "mmmmmmm" sound is coming of you know what i mea :-/
stefan
200 miles from Struer
stefan replied on Mon, Aug 19 2013 2:44 PM
Are you sure that you use a 7 pin datalinkcable connected to TV/AUX on BM7000 and AUDIO AUS LINK socket on 1611?
And did you try an additional Poerlink cable connected to PL/BM7000 and PL/converter?
Your system is set to V.OPT2 and A.OPT0?
When you select another audiosource - same result? (Asked before but ...)
Stefan
André S
Roskilde
I have never try powerlink from bm7000 to 1611 PL in:-)
will it not do some thing bad to it
stefan
stefan replied on Mon, Aug 19 2013 4:15 PM
situation:
Sure - it might work!
I`d recommend to search in the old forum and have a look at the PCG.
Can be downloaded here on Beoworld.
I guess you will find exact this information....
Stefan
Millemissen
Flensborg, Denmark
There is no need for the PowerLink cable running parallel to the AUX cable.
Only gain is that you can turn on the sound from the videosystem, when you start a source manually on the audiosystem, and that the audiosource shuts down, when you switch to a videosource (with the Beo4).
I have had a similar setup for years (actually for decades now) - at first with an Avant and now with a BV8-40 as videomaster, and never got the PL cable connected.
No problems there - on the contrary: I can plug in my headphones to the audiosystem, start the audiosource and turn up/down the volume manually without switching the videosystem on.
I must say that I am at a point where I don't understand, where the problem in the 'situation-setup' can be located.
Next thing I would do is swapping the audiomaster with another. But not everyone has a 'spare' MCL-based audiosystem at hand Crying
Greetings Millemissen
Magnus
Norway
Magnus replied on Mon, Aug 19 2013 10:30 PM
Noise in the audio and no control sounds like a cabel issue to me... Are you sure all the cables are properly in their sockets?
Millemissen
Flensborg, Denmark
I have asked that - but I still wonder if it is so?
André S
Roskilde
André S replied on Mon, Aug 19 2013 11:21 PM
Im now going to say f*** it and then buy new cables and see if that works and if not im goi g to return the 1611 and get a new one.
i will report back later when its don :-) thanks all for you're time
Page 2 of 2 (22 items) < Previous 1 2 | RSS
