Age Old Issue - BeoV 7/32 MKIII + Apple TV
Not Answered This post has 0 verified answers | 23 Replies | 2 Followers
Mark
London
Mark posted on Wed, Jul 31 2013 5:44 PM
Ok age old problem how to connect Apple TV to 7/32 MKIII.
Has anyone used a HDMI to SCART converter, does it work and do you loose any picture/sound quality.
And could you retrofit HDMI to this model TV
Also what is the best product you have found to clean the screen glass, 4 year old finger prints are a cleaners nightmare
Many thanks all
Millemissen
Flensborg, Denmark
I use this one on my old Avant:
http://www.amazon.co.uk/SCART-Converter-Adapter-quality-converter/dp/B007WRPJX2/ref=sr_1_1?ie=UTF8&qid=1375256463&sr=8-1&keywords=Hdmi+to+scart
Easy to set up - not the best picture, but it won't get better.
A compromise, but allows me to use the ATV in the linkroom.
bayerische
Ekenäs, Finland
Isn't there a DVI-input on the BV7 32"?
Too long to list....
Mark
London
Mark replied on Thu, Aug 1 2013 9:39 AM
Yes there is, but is my understanding on the DVI connection correct it only allows pictures not sound and I would have to install an Optical to Analogue converter for sound from the Apple TV.
Or would this route give me a better picture and sound quality ?
kallasr
Germany
For sure a better Picture AND digital Sound
Sound improvement:
depends on your Speaker set-up,
- if you use TVs Speakers only, Sound Quality is not an issue
- if you have a 5.1 set-up, via Scart this it is not possible to feed 5.1.
Ralf
HDMI / DVI = digital Signal with Resolution made for your tv (720p, 1080i etc.)
Scart = Lower Resolution, TV has to do upscaling...
Living Room: Beosystem 4, Beolab 7-6 (Center), Beolab 8000 (Fronts and Rears) and Beolab 2. Screen: Panasonic TX-P65STW60
Home Cinema: Beosystem 4, Beolab 7-2 (Center), Beolab Penta 2 (Fronts), Beolab 4000 (Rears) and Beolab 2. Projector: Sony VPL-HW55
Home Office: Beovision 10-40 on STB Bracket wall mount masterlinked to Beosound 9000 MK3 on horizontal wall bracket driving Beolab 5000 Speakers
Bedroom: Loewe TV with Beolab 6002 and Beolab 11 (all White)
Jonathan
Melbourne, Australia
So just to confirm, the DVI takes sound as well as picture? So all that is needed is a DVI -> Scart cable?
x:________________________
DMacri
United States
DMacri replied on Thu, Aug 1 2013 11:45 AM
No, DVI is for video only. It can't carry audio like HDMI does.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, and ambio
Chris Townsend
Badsey, UK
No, I believe it effectively supplies the same image as HDMI but without the sound. That's always the balls ache problem. Trying to find a sound source!
Beovision Eclipse, Beolit 15, Beoplay A2, H6/H2, Form 2, Beoplay A3, Beovision 5-42 connected to a DVD1
Mark
London
Mark replied on Thu, Aug 1 2013 4:46 PM
interesting thread on Apple Community https://discussions.apple.com/thread/2611942?start=0&tstart=0 about the HD Fury
Mark
London
Mark replied on Sun, Aug 4 2013 9:45 AM
So I've ordered a Sounds Heavenly DVi to HDMI converter, a Lindy SPIDIF Digital to Analogue Audio Splitter and high quality leads.
I did a lot of research on the HD Fury and it seems you would still have a sound issue so defeats the cost (feel free to correct me on this)
Will give an update next week on how it went.
Question - Could you upgrade/retrofit HDMi to the BeoV 7/32 MKIII ?
Mark
London
Mark replied on Thu, Aug 8 2013 10:24 AM
All connected and working now and I must say I am rather impressed with the picture and sound quality when you take into consideration the the cabling and splitters involved.
What I like about doing such things and posting on this forum is what you learn, how boring if life was just all plug and go.
BeoHut
BeoHut replied on Thu, Aug 8 2013 10:58 AM
Hi Mark,
Good to know that this solution works. There are a lot of questions here on this forum about connecting Apple products to older Beovisions.
Thanks for sharing this solution with us and enjoy your upgraded setup! Hope it will do for the next few years.
Millemissen
Flensborg, Denmark
Note: the BV must be HD ready - otherweise this wouldn't work 'out of the box'.
I suppose a BC7-32 MK3 is!
BeoHut
BeoHut replied on Thu, Aug 8 2013 11:12 AM
Millemissen:
Correct Millemissen!
A good addition for the other members on this forum.
Page 1 of 2 (24 items) 1 2 Next > | RSS
