beolab 6000 please help
Answered (Not Verified) This post has 0 verified answers | 4 Replies | 2 Followers
richersounds
richersounds posted on Tue, Jul 23 2013 12:58 AM
Hi, i just bought a pair of beolab 6000 speakers. i don't have the system/amplifier that these work through.
I want to test that they are in working condition.
How can i do this without the correct system?
Any help would be very appreciated. thanks
Hubbe
Hubbe replied on Tue, Jul 23 2013 2:23 AM
It is possible to play music from your smartphone, iPod and similar devices. I have never tried it myself. Someone else will probably write what kind of cable you need. It should be quite easy to find the answer if you use the forums search function or search on google.
Good luck!
KingOfSnake
Suggested by KingOfSnake
use with phono cables and change the switch to line - use an amp with pre-outs.
KingOfSnake
kallasr
Germany
STEVE has a cable that will do the job.
Ralf
Page 1 of 1 (5 items) | RSS
