Beo5 battery
bayerische
Ekenäs, Finland
Posts 4,770
bayerische Posted: Thu, Jul 4 2013 8:14 AM
Hi guys,
Is the battery in the Beo5 self replaceable? Mine is almost dead, it only keeps it's charge a few hours. A pity since I really like the Beo5.
Too long to list....
Keith Saunders
Hampshire, United Kingdom
Posts 5,480
Provided you have the correct size splined screw driver and a new replacement battery, you can replace the battery yourself.
Have a look HERE for details
Regards Keith....
bayerische
Ekenäs, Finland
Posts 4,770
Is the battery available from elsewhere than B&O?
Keith Saunders
Posts 5,480
Possible, but I have never seen them.
The batteries are made by Sanyo NI-MH model # 2HR-4/5AAU and are 2.4 volt
Regards Keith....
bayerische
Ekenäs, Finland
Posts 4,770
Keith Saunders:
Thanks Keith!
I ordered it from the dealer.
bayerische
Ekenäs, Finland
Posts 4,770
Dealer price was pretty steep at 60 euro, just as a heads up to the rest of you.
Got it today, and is now changed thanks to Keith's instructions. Yes - thumbs up
Tillquist
Posts 225
Tillquist replied on Mon, Jul 29 2013 1:43 PM
bayerische:
Wau, in denmark its cost 30 euro
My Bang & Olufsen....
  • BeoCenter 2 DAB/DVD mk.II
  • BeoVision 7-40 DVD mk.III
  • Beo 5
Aleksei
Estonia
Posts 22
Aleksei replied on Tue, Jul 30 2013 11:02 AM
If you have soldering skills, can try eBay item: 290764725982.
Looks like correct size 4/5AA (original Sanyo spec is here: http://www.manualslib.com/manual/148324/Sanyo-Twicell-Hr-4-5aau.html)
item 290764725982 Technical specifications
  • Size: 42mm (length) x 14mm (hight) x 28mm (width)
  • Chemistry: NiMh (Nickel Metal Hydride)
  • Output Voltage: 2,4V
  • Amperage: 2x 1200mAh
  • Battery Terminals: Flat terminals, tagged on both ends for soldering
Aleksei
Page 1 of 1 (8 items) | RSS
