From Masterlink to Mini Jack
Answered (Not Verified) This post has 0 verified answers | 3 Replies | 0 Followers
DoubleU
DoubleU posted on Fri, Mar 30 2012 8:35 PM
I need to extract audio from masterlink to a 3,5” minijack TRS (Tip Ring Sleeve)
Should I connect it  like this?
Masterlink            >>   minijack
White/Orange -L   >>  Sleeve
Orange +L            >>  Tip
White/Red -R       >>   Sleeve
Red +R                >>   Ring
Langleyav
Windsor UK
Silver Member
Suggested by Langleyav
Masterlink audio is distributed in a BALANCED audio format, so ideally you should insert a 1:1 ratio audio transformer in each channel, then you can UNBALANCE the audio to go into your minijack.
Ron
akoro
akoro replied on Sat, Mar 31 2012 10:45 AM
DoubleU:
Orange L >> Tip
Red R >> Ring
Connecting like that would give you zero volume/sound. You should be able to get sound by connecting sleeve to masterlink shield and red and orange as you figured out.
Problem here is that you are opening masterlink to outside noise as the balancing is effectively lost.
Best idea would be to build an active circuit that would convert balanced to unbalanced signal like BeoLink Active does.
DoubleU
Oke, first I'll try without the BL-Active, solder a minijack straight to the ML, and go from there. If there is too much noise in the rest of the existing ML-wiring I will add the active kit.
Thanks for both answers!
Page 1 of 1 (4 items) | RSS
