Beogram CD 50, Mexico
This post has 172 Replies | 3 Followers
twomartinis
Posts 2
Hi everyone,
Bumping this thread as the drive belt in my CD-50 is on its last legs. Can anyone offer proper belt dimensions? Preferably in standard naming SCY##, SCX## etc. Mine is woefully stretched and hardened or I would put the calipers on it. https://www.elliottelectronicsupply.com/square-drive-belts.html
I have fashioned a makeshift tensioner out of some teflon wire to keep her in service until I can get a new belt. The cam follower/CD spindle lift at the end is soooo slow. A re-lube is in order too, running the sled in and out feels really tight & sticky. What is a good white grease to use?
Søren Mexico
Mexico City
Posts 6,353
Welcome to the forum, member Dillen ( Martin) on this forum can provide the correct belts, I have been using a silicone grease for my units
Dillen
Copenhagen / Denmark
Posts 11,255
Dillen replied on Tue, Apr 2 2019 7:20 AM
twomartinis:
White lithium grease.
As the original.
twomartinis
Posts 2
Thanks, anyone know the drive belt dimensions? Cross section and inside circumference? I suppose I could figure it out (or at least get close); but I'd rather have the correct information...
chartz
Burgundy, France
Posts 3,890
chartz replied on Tue, Nov 19 2019 1:44 PM
Hi everyone,
Would one of you mates have a spare Beogram CD50 IR module, sans CD controler?
If so, please send me a PM.
Thanks! Smile
Jacques
Søren Mexico
Mexico City
Posts 6,353
Hi Jacques, I have 2 CD 50 not working, send me a pic of the IR module and I will open them to look for it. if one of them have it, I can send it with my son to Copenhagen in January, and he to you from there
chartz
Burgundy, France
Posts 3,890
chartz replied on Tue, Nov 19 2019 7:02 PM
Hi Soren, very nice of you my friend.
The module is right behind the fascia, let me find a pic.
Edit: here it is!
The module with the tin box and the brown wire.
Jacques
Søren Mexico
Mexico City
Posts 6,353
Will get to it tomorrow
chartz
Burgundy, France
Posts 3,890
chartz replied on Tue, Nov 19 2019 8:02 PM
Cheers! ¡ Gracias ! Tak!
Jacques
Søren Mexico
Mexico City
Posts 6,353
Sorry Jacques
Søren Mexico
Mexico City
Posts 6,353
One more sorry
chartz
Burgundy, France
Posts 3,890
chartz replied on Wed, Nov 20 2019 8:48 PM
Okay then, never mind 😢
Thanks for looking!
Jacques
evald
Posts 1
evald replied on Fri, Nov 29 2019 2:45 PM
Thank you Søren, excellent writeup now my CD50 is as new after 10+ years in the closet.
A note on the turntable height, my service manual says adjust to 4.9 +/- 0.05 mm.
That is too much in my player, used a 4,5 mm drill bit for spacing with success.
The belt dimension is 43.5 x 1.40 mm square.
Page 5 of 5 (173 items) < Previous 1 2 3 4 5 | RSS
