NL/ML Converter issue
Not Answered This post has 0 verified answers | 23 Replies | 2 Followers
berlin2010
berlin2010 posted on Sat, May 25 2013 3:37 PM
NL/ML Converter not working, hoping those of you with more experience can help.
My setup is as follows:
BS9000 (with BL8000 directly connected) has a ML connection directly to NL/ML converter.
NL/ML Converter connected to Apple Airport Extreme.
BV11-55 connected to Airport Extreme.
BS9000 standalone works just fine, BV11 works fine, including Webmedia etc. so pretty sure the connection between BV11 and Airport Extreme is fine (Youtube streaming from iPad fine, BeoRemote app works etc.)
The BV11 also definitely 'sees' the NL/ML Converter, it allows me to select it in the Product Integration B&O Connect submenu.
Yet when I select AV > Radio / Cd etc. on Beo4 I get a screen that displays Radio From Beolink Converte NL/ML and then after a short while it says Failed... Grrrrr...
I once or twice had it showing Connecting (in lieu of failed) but that also changed to Failed after 30 seconds or so.
Some thoughts,
Do I have to connect the equipment in a specific sequence?
Do I have the turn the bits and pieces on in a specific sequence?
What is the function of the reset button on the NL/ML Converter? (If you press and hold, the small green Light goes dark and then flashes red once - if I release it changes back to green. If I keep holding it flashes red twice, three times etc. does that make a difference?)
Should the BV 11 / BS900 be in particular option settings? BV11 currently Option 1 and BS9000 also option 1 since although technically in two rooms it's an open plan environment so any keypress on the remote is seen by both.
Any thoughts?
PS. The Airport Extreme is set up as a router (i.e. it has DHCP active and issues IP's handles NAT etc.) - direct cable connection from the WAN Port to Internet. I assume this is correct - saw a diagram to this effect somewhere on this forum.
1983beo
Berlin
Update your ml-nl converter and the problem is solved. As the tv has new software 1-2weeks ago and won't work with an not updated nl converter.
When update the converter also put the checkbox automatic updates on. So this won't happend next time.
berlin2010
1983beo:
Berlin
Apologies if the answer is obvious, but how do i update the NL/ML converter?
Answered my own question - never dawned on me to look for a HTML user interface.... got that far; busy updating software now. Thanks
berlin2010
Another question for those in the know. Can i (should I?) see the names of the different radio stations on my BV11 when using it via NL/ML converter?
On the BS9000 all the stations have names but the BV11 simply displays 'Radio' in the middle of the screen... even a simple station1, station 2 etc. would've been nice when changing stations.
1983beo
Berlin
No thats not possible. The nl converter only show radio no channel info.
berlin2010
Thanks 1983beo. Something to look forward to in a future software update perhaps.
Beoberg
Odense, Denmark
Hi Guys,
Just bought the NL/ML converter and I am having similar problems as berlin2010. BeoVision 11 clearly detects the converter and starts the television up when I press CD on my BeoCenter 2, but after a short while it says "failed". The solution should be updating the BeoLink converter but how do I do this? I can not seem to find any HTML interface for the converter as Berlin2010 talks about.
In the menus I only seem to find the BeoVision 11 TV firmware update which is already set to automatic update.
BeoVision Eclipse 55, BeoPlay S8 (sub+rears), BeoPlay A9 MKII (living room), BeoVision Avant 32 DVD (retro gaming, basement), BeoLab 4000 (entertainment room, basement), BeoSound 8 (workshop), 2x BeoPlay S3 (PC), BeoPlay A1, BeoPlay H2/H3 (on the go)
Vienna
make an educated guess
Vienna replied on Wed, Jun 26 2013 9:22 AM
Frederik Beoberg:
Using a standard RJ45 cable, connect a computer directly to the ethernet port of the converter.
Start your browser and access the ML/NL-Converter via it's HTML user interface.
Millemissen
Flensborg, Denmark
The converter should by default be set to 'autoupdate' - if so, it is already utodate.
You can check this by accessing the web interface of the NL/ML....(as Vienna describes).
What colour is the status led on the converter, when you get the 'failed' message?
Did you set it up yourself?
Greetings Millemissen
Beoberg
Odense, Denmark
Thanks for the quick responses! I bought on sale at a stock clearout from an B&O in-store, so no service at home. I understand that I have to connect the converter to my PC, but how do I access the interface? Do I have to put in an IP address or something in the browser as with a router? The LED on the converter is steady green.
Millemissen
Flensborg, Denmark
The converter gets (if it is set as default) an IP adress. You should be able to find it on your network.
Connecting it directly to a pc is one way (as Vienna wrote).
You could also (if all is connected to a wireless router) do the following:
- Open the Internet Browser on the iPad/iPhone (‘Safari’).
- Enter ‘BLC-’ followed by the BeoLink Converter NL/ML serial number: BLC-XXXXXXXX.local.
The username and the password is by default 'admin' 'admin' (hopefully not changed?)
Now you can access the userinterface.
 Under 'tools' you can see the softwareversion and update/set to autoupdate.
NOTE: it is recommended from Bang & Olufsen that a NL network ( including the converter) is set up wirh a seperate router as a subnetwork!
imac
Germany
imac replied on Wed, Jun 26 2013 9:56 AM
Millemissen:
My converter was also set on autoupdate, but for some reason it didn't work with the last software update of the BV11. I heard from my dealer, that this problem showed up with several clients.
Beovision 11-55, Beovision 10-46, Beovision 7-40, Beocenter 6-23, Beosound 9000, Beolab 18, Beolab 19, 2xBeolab 3, Beolab 8000, Beolab 6000, Beolab 2, Beocom 6000, Beosound 3, Playmaker
Vienna
Vienna replied on Wed, Jun 26 2013 9:59 AM
- disconnect ML/NL from mains
- after a few seconds restore power and wait till the LED stops flashing green
- using your browser enter: 169.254.11.22
- a log in screen opens, please enter
- default user name: admin
- default pwd: admin
Beoberg
Odense, Denmark
Beoberg replied on Wed, Jun 26 2013 10:09 AM
I have access to the interface now, thanks! It says that the software version is 1.0.0.0. Automatic update was set disabled. But when I ask to update the software it does nothing.
Millemissen
Flensborg, Denmark
Frederik, I am sure you will have to  describe how your setup is/how the converter is connected to your network to get further help!
Page 1 of 2 (24 items) 1 2 Next > | RSS
