Beo 7 40" - HDMI and Apple TV problem
This post has 10 Replies | 2 Followers
Chelseabaileydog
Posts 3
Chelseabaileydog Posted: Mon, Mar 25 2013 1:20 PM
I only have 1 DVI port which I have an adapter converting to HDMI for Sky. I have now recently purchased Apple TV which is only HDMI. I have to remove the lead from Sky into Apple TV. There is no sound on the Apple TV. Is there any way I can have my Sky and Apple TV connected without unplugging one of them for the other. Also, how can I get sound for the Apple TV as it only has optical audio port? I hope this is not too complicated and I apologise for the poor tech speak. Please keep answer simple as I'm not a big technical person!!
Millemissen
Flensborg, Denmark
Posts 14,593
Hi and welcome to BeoWorld,
please do not think that I am unpolite - but the simplest answer to your question is: do upgrade your BV to a version with HDMI-inputs.
Sure there are some other solutions for your problem. But they would be rather tricky, if you don't want to mess with switches and converters and - perhaps - updating the SW of your tv.
Greetings Millemissen
DrDimitris
Greece
Posts 699
Solution is simple.
1) Buy a splitter like this: http://www.azcotechnologies.com/azhdmis13------hdmi--1x3-switcher/product/47/3/
2) Use an optical to digital audio convertor like this: http://www.atlona.com/Atlona-Optical-Digital-Coaxial-2-Way-Converter.html
Thats all.
Dimitris-
DoubleU
Posts 562
DoubleU replied on Mon, Mar 25 2013 4:25 PM
Probably not all.. Software for the DSM-module must be at least 3.01 (not likely) Otherwise the TV won't accept PCM-stereo, only 5.1   And like Millemissen said, SW update for the tv must be up to date.
Both software updates also needs to be done with hardware chips.
Millemissen
Flensborg, Denmark
Posts 14,593
...and he needs a switch for the sound-inputs.
That is why I presented 'the simple solution': upgrade the tv!
vlohjr1
Posts 545
vlohjr1 replied on Mon, Mar 25 2013 5:59 PM
Agree even the mkiii screen only are reasonable in price these days...
Regards
Vince
Chelseabaileydog
Posts 3
How do you switch between Sky and Apple TV when they are going through one port
Chelseabaileydog
Posts 3
How do you upgrade your current tv or are you talking about me selling and buying a new tv
vlohjr1
Posts 545
vlohjr1 replied on Tue, Mar 26 2013 12:40 AM
I presume yours is a mkii just part exchange it for a mkiii or upwards screen with or without DVD inbuilt. Unfortunately your mkii screen I suspect would not worth more than 500£ I guess. Without inbuilt br player there is an extra hdmi connection
There are some good offers for a new bv740 in the dealers
Good luck
Bince
DrDimitris
Greece
Posts 699
Chelseabaileydog:
By pressing the button on the HDMI splitter. Of course you have to assign via your BV7-40 Connections MENU the different sources. For example: SKY (V.MEM) and ATV (V.AUX).
And yes, your TV has to be software and hardware updates for PCM sound (not so expensive upgrade).
My answer is that it is possible EASILY to do it. I have done it also and many others in the forum.
When someone asks how do i put snow tires in my car, i do not think the answer is buy a 4X4 SUV car.....
Dimitris-
AlanRooms
Posts 1
AlanRooms replied on Fri, Mar 29 2013 3:36 PM
Use a  hd fury. Look it up on internet
Page 1 of 1 (11 items) | RSS
