Beolink 1000
Not Answered This post has 0 verified answers | 5 Replies | 0 Followers
Paulo Alexandre GTF
Paulo Alexandre GTF posted on Fri, Jan 14 2022 10:28 PM
Hi, i just bought a beolab 3500 and a beolink 1000 remote, with no menu button, and i saw that pressing shift + text would start the menu but it doesnt. Can someone help me please
Millemissen
Flensborg, Denmark
ONLINE
Hi and welcome to the forum.
The Beolab 3500 is a speaker, a linkroom speaker intended to play what can be played on a Beosound (of some kind e.g. a BS9000) when it is connected through Masterlink.
There really is no menu to access - apart from a service menu, which is another subject.
You access the sources of the main audio system by pushing Radio, CD or alike - it has no sources of its own.
How are you hoping to use the BL3500 - for what?
Paulo Alexandre GTF
Hi, thanks for the reply.
I dont have any B&O device, but i saw online that it can be connected to a ipod for example, with a 7 pin cable to mini jack ( that i have ), and then using a beolink 1000 remote ( i bought one ) you should press menu 0 4 go, to go to MCL mode. On the mk1 remotes that dont have the menu button, you should be able to reach menu pressing shift+text, but im not able to do that when i press it. I press shift text and nothing happens
https://www.soundsheavenly.com/48-masterlink-control-and-sync
Guy
Buckinghamshire
ONLINE
Guy replied on Sat, Jan 15 2022 10:45 AM
Just to be sure, to get MENU you need to press SHIFT then TEXT, not both at the same time.
Paulo Alexandre GTF
Thak you so much Guy. I got it.
Millemissen
Flensborg, Denmark
ONLINE
Also see Steve’s post here:
https://forum.beoworld.org/forums/p/28348/354472.aspx#354472
Page 1 of 1 (6 items) | RSS
